 separating body from frame..
crazy58fury
PostSubject: separating body from frame..   Wed Jul 18, 2012 3:46 pm
Hey Guys, I had a question for you, How can I go about taking the body off the frame? Can I use some jack stands and wood or somthing to get it off? scratch
ty
Kiddo if you sold him that piece of crap you atta be frikin ashamed of yourself
PostSubject: Re: separating body from frame..   Wed Jul 18, 2012 6:12 pm
a pair of 4 x 4s ja4 jacks and 4 jackstands, I used a cherry picker and 2 jacks to seprate
crazy58fury
PostSubject: Re: separating body from frame..   Wed Jul 18, 2012 7:16 pm
Would it be possible to put 4 jacks on each corner of the car and then lower the body and frame down then the body would rest on those then I could put the 2 4x4's under the supports, then roll the frame out? could that work?
PostSubject: Re: separating body from frame..   Wed Jul 18, 2012 10:21 pm
Here ya go Ty.... This is the dangerous way and I would recommend using the Mechanic Shop "Finger type Lift" that will lift your body off evenly and safely. Well if you have no choice this is the way I did it and had multiple Jack's and other Friends to lift Body off.
PostSubject: Re: separating body from frame..   Wed Jul 18, 2012 10:54 pm
That will work Smile
crazy58fury
PostSubject: Re: separating body from frame..   Thu Jul 19, 2012 7:26 am
Hey thanks joe! How did you get the car on to the 4x4s though?
ty
PostSubject: Re: separating body from frame..   Thu Jul 19, 2012 10:10 am
As the body is completely unbolted from the frame and laying there, my friends lifted up on the front, tilting the body up just enough to pass the 4x4 across then we did the same for the rear. The wood sits on the frame holding the body until you jack up the wood/body high enough to clear then place the wood on jack stands safely.
DO NOT TRY THIS BY YOURSELF, YOU COULD GET HURT!
crazy58fury
PostSubject: Re: separating body from frame..   Thu Jul 19, 2012 10:25 am
I was thinking about havin some of my uncles come over to help me?
ty
PostSubject: Re: separating body from frame..   Thu Jul 19, 2012 11:43 am
That sounds like a Plan Ty:)
PostSubject: Re: separating body from frame..   Thu Jul 19, 2012 12:43 pm
you are da man joe thanks for putting the pictures up it shows it much better then just describing it
