Today at 2:29 pm by Christinefan824
Today at 1:44 am by Christinefan824
Yesterday at 6:39 am by eva_392
 8-3/4" article in Car Craft magazine-Junk yard builder
PostSubject: 8-3/4" article in Car Craft magazine-Junk yard builder   Tue Aug 07, 2012 7:19 am
October 2012. The take a '489' case and load up a sure grip and ring gear with a modified crush sleeve. good pics and info. Marc
Evilstretch
PostSubject: Re: 8-3/4" article in Car Craft magazine-Junk yard builder   Tue Aug 07, 2012 8:03 am
Hey Marc is this online ?? Do you have a link for us ??
[b]If it's an ambulance
You've got a chance
But if it's a hearse
It's got to be worse.
PostSubject: Re: 8-3/4" article in Car Craft magazine-Junk yard builder   Wed Aug 08, 2012 6:48 am
It is not on line yet. (unless you have an online subscription) Page 70-74 October 2012 Car Craft Mag. The jist is using a non crushable sleeve in he 489 case by Ratech. PN 4103. $33 RatechMFG.com 513-742-2111 Then shim it as if it were a 741,742 diff. They lucked out and built one out of 2 for < $400! Marc.
PostSubject: Re: 8-3/4" article in Car Craft magazine-Junk yard builder   Mon Sep 24, 2012 8:42 am
That is what I have been doing for years. The stock crush sleeve can crush more under heavy use and kill your gears. That is why a lot of racers liked the 742 case. The 489 has a larger tapered pinsion (1 7/8") that does away with a stress riser that is on the smaller (1 3/4") on the 742 pinion.
Funny mopar based trivia - the 741 case which is considered the weakest, has a larger pinion and bearings that the 12 bolt chevy and the 9" ford. The ford does have the additional rear pinion bearing advantage however.
