» Bumper wings
Mon Jul 16, 2018 4:54 pm by Bloodhound1958
» Sorry for the stupid question
Sat Jul 14, 2018 9:31 pm by eva_392
» Something fun for Friday the 13th!
Fri Jul 13, 2018 10:09 pm by Christopher L. Faddis Usn
Fri Jul 13, 2018 10:02 pm by Christopher L. Faddis Usn
Fri Jul 13, 2018 9:57 pm by Christopher L. Faddis Usn
Fri Jul 13, 2018 6:25 pm by 58belvedere
» What Do You Expect?
Wed Jul 04, 2018 6:13 pm by goat19642004
» Steering Gear Tube Insulator ?
Sun Jun 24, 2018 7:27 am by Jurrasic car
Thu Jun 21, 2018 5:16 pm by 58belvedere
 Air Ride suspension
Black Rock Fab
PostSubject: Air Ride suspension   Wed Sep 12, 2012 1:27 pm
Hey Guys, i was wondering if anyone has seen or tried an air ride suspension? Im not talking about "slamming " to the ground or anything. But just to improve ride quality and appearance. Would anyone be interested in a kit if i were to design and build one? thanks kyle
WWW.BLACKROCKFAB.COM
http://www.facebook.com/pages/Black-Rock-Fabrication/317930084884009
http://www.BlackRockFab.com
PostSubject: Re: Air Ride suspension   Wed Sep 12, 2012 4:02 pm
I personally am more of a stock guy, but it sounds like a great idea for those willing to improve upon their cars. I'm sure you'll get some good feedback here.
Black Rock Fab
PostSubject: Re: Air Ride suspension   Wed Sep 12, 2012 9:22 pm
Cool, thanks for the input John. Thanks Kyle
PostSubject: Re: Air Ride suspension   Wed Sep 12, 2012 10:09 pm
Kyle Im with John, a 58 Plymouth with good Power steering and Good Torsion bars are about as good as it gets for me. I don't like cars that are so smooth they put you to sleep, But IKm sure some of the younger gujys likes things a little more coosie. Hee! Hee!
PostSubject: Re: Air Ride suspension   Thu Sep 13, 2012 5:57 am
Im not too sure that the stock PLYMOUTH frame will allow for air springs/shocks on the front.
the frame is quite 'thin' up front compared to a GM based car (which you see alot of Air Ride shocks on) I think you would have to radically modify the fame to fit airride.......but with advances in technology there may be some new systems you coould probably just bolt in? Chaney might be able to answer this one!
Would be a great idea if you could design one Kyle......
PostSubject: Re: Air Ride suspension   Thu Sep 13, 2012 9:37 am
Well all the old hotrodders have a saying if you have a big enough cutting torch you can make anything fit Hee! Hee!
Black Rock Fab
PostSubject: Re: Air Ride suspension   Thu Sep 13, 2012 10:44 am
sajase57 no problems with fabbing stuff. If you check out my website you will see i do alot of fab work. I have a cnc plasma cutter in my shop so re-enforcing the frame would be no problem. Soon as i get a car first thing i do will be looking into this. thanks kyle
Black Rock Fab
PostSubject: Re: Air Ride suspension   Thu Sep 13, 2012 10:50 am
Also, when i do design the kit i will keep in mind the end user. So if i can make as much bolt on as i can i will. But obviously plates to reenforce the frame will need to be welded on.
58plym, that's how i was taught and raised. If it don't fit. Make it fit by all means necessary Smile
PostSubject: Re: Air Ride suspension   Thu Sep 13, 2012 6:49 pm
Thats a great phillosophy Kylie.........
Cant wait to see your progress.
Black Rock Fab
PostSubject: Re: Air Ride suspension   Tue Oct 02, 2012 11:16 am
Hey guys, does anyone know the WMS-WMS (wms= wheel mounting surface)on the factory front suspension of these cars? thanks kyle
PostSubject: Re: Air Ride suspension   Tue Oct 02, 2012 7:34 pm
Hee! Hee!
PostSubject: Re: Air Ride suspension   Wed Oct 03, 2012 2:49 am
Hey Kyle,
Wheel Mounting Surface? Hhmmmm? Well the stub axles are mounted to upper and lower control arms. the upper arms are mounts via bolts/bushes directly to the frame. the lower arms and on a pivot bolt mounted drectly to the torsion bars which are anchored to the frame.
Will try to get you a pic or image.........Not sure if this is what you want to know?
Air Ride suspension
The Christine Car Club :: Christine Car Club Tech Section :: Steering and Suspension:-
