 Fitting Windscreen glass with new rubbers
25tj25
PostSubject: Fitting Windscreen glass with new rubbers   Wed Sep 12, 2012 9:37 pm
Hi fellow CCC members
I bought new windscreen rubbers for Andy B's
didn't realise they are not 1 piece like the originals
anyway, has anybody fitted new rubbers before
also does anyone have images how the rubber extrusion is fitted to the car frames
as I have a pile of rubber in a box, I did order front and rear's Neutral
thanks
knighty
PostSubject: Re: Fitting Windscreen glass with new rubbers   Wed Sep 12, 2012 9:56 pm
Knighty, Yea I tried everywhere to get a new one piece front seal but no luck, I finall found a like new used one. I know they are people Like John Big M and others can help you ouit with how to inhstall and everything a lot better then I Smile
25tj25
PostSubject: Re: Fitting Windscreen glass with new rubbers   Wed Sep 12, 2012 10:20 pm
the worse thing is mine originals were not to bad, a little perished
was told to put them in tranmission oil for awhile. well I had them in there for nearly 2 years Crying or Very sad
and now they are big enough to fit a kenworth windscreens.
so I bought new ones and got a box of rubber extrusion Shocked
do you know Big M's PM as I have some parts I need too!
knighty
PostSubject: Re: Fitting Windscreen glass with new rubbers   Thu Sep 13, 2012 5:36 am
Hey Tim,
I bought an origonal rear rubber from John. He gave me the best one he had which was a little dry. I put the rubber in trans fluid also to make it a little more flexible.
it actuall grew in the fluid as it expanded and I had it on my shed roof all sumer to try to dry it out. It didnt work so i sat the rubber in the apeture and taped it to the car body and cut the excess and glued the ends together with LOCTITE 501 superglue. Its a fiddly job but my rear screen is water tight and still in there. the glue held really well too and hasnt split at all. you could do the same thing with the 1 piece rubber but you would have to watch the corners as they are not moulded to the corners. If your old rubber is in good order you could always cut the corners to rebuild the rubber seal. This would be pretty risky as you could stuff up a good origonal rubber and the new one if you dont get it right!
PostSubject: Re: Fitting Windscreen glass with new rubbers   Thu Sep 13, 2012 9:35 am
Yea That would be worth a try. Smile
25tj25
PostSubject: Re: Fitting Windscreen glass with new rubbers   Fri Sep 28, 2012 12:55 am
Hey Jase and Rob,
thanks for the replies, just checking if any responses and here they are.
ok will try the loctite 501 - I had mine in the tranny oil way to long. they are that soft and expanded to much.
the 4 items I have I worked out which goes were, just wasn';t sure how to join them but you answered it so thank you.
The originals have moulded corners so the new rubber I'm not really impressed with, I didn't know they had to be made up
but dont have much choice I guess. I emailed AB and no response or help either so that it disapointing
will give it ago gents and hopefully it works out ok
thanks for the replys fellas
tk
