Yesterday at 7:19 pm by 58belvedere
 1958 Belvedere 318-350 swap
ucanown1too
PostSubject: 1958 Belvedere 318-350 swap   Thu Dec 13, 2012 9:09 pm
Hi all brand new to the forum. We have a 1958 Belvedere at our shop that we are doing a long term build on. The car is originally a 318 car but our customer bought a 350 golden comando engine to install in it. We just recently got it back from the engine builder and I installed it along with the used bellhousing yesterday. After bolting everything down the engine looks crooked or maybe even cocked in the engine compartment. Both motor mounts are sitting in the frame mounts correctly, all 8 converter bolts are tight and bolted in straight and the bellhousing is flush to the engine. I know the frame mounts are off center but this thing looks crooked. Anybody ever run into this problem?
ucanown1too
PostSubject: Re: 1958 Belvedere 318-350 swap   Thu Dec 13, 2012 9:14 pm
PostSubject: Re: 1958 Belvedere 318-350 swap   Thu Dec 13, 2012 10:35 pm
Tough to diagnose without knowing what you started with. Judgeing by the title of this post the car had a 318. Was it a factory original V8 car? How about the motor mounts. 361 B block mounts will not work. They are different from the 350 mounts. Read this (about 3/4 of the way down the page) and check the pictures for reference purposes....
http://www.christinecarclubforum.com/t908-bloodhound-s-1958-plymouth-christine-restoration
ucanown1too
PostSubject: Re: 1958 Belvedere 318-350 swap   Thu Dec 13, 2012 10:46 pm
Bloodhound1958 wrote:
Tough to diagnose without knowing what you started with. Judgeing by the title of this post the car had a 318. Was it a factory original V8 car? How about the motor mounts. 361 B block mounts will not work. They are different from the 350 mounts. Read this and check the pictures for reference purposes....
Man thats a big help! Looks like the mounts that came with the 350 are wrong. I will have to check when I get out to the shop in the am to be sure. Thanks!
ucanown1too
PostSubject: Re: 1958 Belvedere 318-350 swap   Thu Dec 13, 2012 10:47 pm
[quote="ucanown1too"][quote="Bloodhound1958"]Tough to diagnose without knowing what you started with. Judgeing by the title of this post the car had a 318. Was it a factory original V8 car? How about the motor mounts. 361 B block mounts will not work. They are different from the 350 mounts. Read this and check the pictures for reference purposes....
And to answer your question....the belvedere was originally a 318 torqueflight car. Do you know where I could locate a set of those mounts?
PostSubject: Re: 1958 Belvedere 318-350 swap   Thu Dec 13, 2012 10:48 pm
Your welcome. If you do have the wrong mounts check with John here on the forum (BIGM). He has if I recall one set left. Just look in the long vertical column to the right and you'll see his number as a Top Rated Seller.
ucanown1too
PostSubject: Re: 1958 Belvedere 318-350 swap   Fri Dec 14, 2012 10:27 am
Thanks a bunch for those pics man they really helped me sort some things out this morning. Looks like I may have 1 350 mount and 1 361 mount. I left John a message so hopefully he will get back to me soon.
PostSubject: Re: 1958 Belvedere 318-350 swap   Fri Dec 14, 2012 10:37 am
John will get right back to you, He is great help and is always on the ball Smile
ucanown1too
PostSubject: Re: 1958 Belvedere 318-350 swap   Mon Dec 17, 2012 3:48 pm
So I have called John 4 times since Friday-left 2 messages and no response. I really need these mounts asap so I can finish the motor swap in this car.
PostSubject: Re: 1958 Belvedere 318-350 swap   Mon Dec 17, 2012 5:32 pm
John has been on a trip to Nevada I hink should be back I sent him a regular email, Im sure he will get ahod of you as soon as possable. Smile
PostSubject: Re: 1958 Belvedere 318-350 swap   Mon Dec 17, 2012 6:59 pm
Here is some pics of my 350/383. I used an old 383 to mockup engine and tranny combo.:
PostSubject: Re: 1958 Belvedere 318-350 swap   Mon Dec 17, 2012 7:46 pm
You know my right side mount will come out of the cup, I mean the rubber out of the cup. bujt when they are in the car and engine set in, no wayh will they pull out, I was going to replace mine and John Big M said you didn't need to it wouldn't pull out, I was thinking the same thing but was glad to hear from a great athority.
Redsled has as much torque as about any of them and I have a 4000 RPM convertor soI don't think anybody would have a problem, so don't worryh ikf theyh are loose in the cup. Smile
PostSubject: Re: 1958 Belvedere 318-350 swap   Mon Dec 17, 2012 8:02 pm
Thanks, Bobby!
I did speak with Larry a short while ago, and should be able to help.
ucanown1too
PostSubject: Re: 1958 Belvedere 318-350 swap   Mon Dec 17, 2012 8:29 pm
Big M wrote:
Thanks, Bobby!
Larry called and let me know he heard from you. Thanks a bunch sounds like you may be able to get it worked out for us.
PostSubject: Re: 1958 Belvedere 318-350 swap   Mon Dec 17, 2012 9:46 pm
Much Goodo Juan.
Roberto Joe
PostSubject: Re: 1958 Belvedere 318-350 swap   Tue Dec 18, 2012 5:01 pm
I do, indeed, have the mounts you need. I've left a message with Larry, so we'll get things going!
PostSubject: Re: 1958 Belvedere 318-350 swap   Wed Dec 19, 2012 4:30 pm
Please check your PM box, Ed.
