 Removing frame
MoparJoe
PostSubject: Removing frame   Mon Nov 14, 2011 3:26 am
hey everyone, well i posted in the old forum but as we know its out of action, at least for now anyway, i just want to know whats the best way of lifting the frame off the chassis? should i jack it up, or should i run some straps around it and lift it with a engine hoist? Any other ideas? Thanks, Joe.
PostSubject: Re: Removing frame   Mon Nov 14, 2011 6:21 am
Joe. I am going to brace the inside of my body a little before I try to lift it off the frame. The rust and age have weakened it and I don't want to twist it in any way. I plan to lift my body off with a four point carlift If I did not have a lift I would Jack her up and roll the frame out from under her. I am building a rotisserie so I will mount the body on that.
PostSubject: Re: Removing frame   Mon Nov 14, 2011 12:23 pm
I use a forklift and trucker's tie down straps to raise the bodies off. Definitely brace the body by using square tubing or c-channel to fit where the doors were. 4 grown men can lift the body off, but to prevent back injury, it is better to use a hydraulic hoist.
PostSubject: Re: Removing frame   Mon Nov 14, 2011 10:56 pm
The other way is to jack the body up slightly or have a couple guys lift front then back and you place a 4X4 between the body and frame. Once thats done, floor jacks until the rear hump clears the 4x4 then roll the frame out.
MoparJoe
PostSubject: Re: Removing frame   Tue Nov 15, 2011 2:23 am
i like the sound of that, what about putting the doors back on for strenght, instead of making braces to stop the body from flexing?
MoparJoe
PostSubject: Re: Removing frame   Tue Nov 15, 2011 2:25 am
i would love a rotisserie
PostSubject: Re: Removing frame   Tue Nov 15, 2011 11:23 am
I have a rotisserie!!!!!!!!!! I cook my chickens on it Razz Razz Razz Razz Razz Razz
MoparJoe
PostSubject: Re: Removing frame   Tue Nov 15, 2011 2:42 pm
can we modify it to fit on a plymouth? lol
Removing frame
