» C@@L pic of Christine with Danica
Sun Nov 18, 2018 11:18 am by ghostsoldier
» Article on Christine
Sat Nov 17, 2018 10:38 pm by 58belvedere
» Deep Roots
Sat Nov 17, 2018 1:00 pm by furvedere
» Fresh Air Intake?
Fri Nov 16, 2018 9:46 pm by 58belvedere
Thu Nov 15, 2018 1:42 pm by JAG
Mon Nov 12, 2018 10:20 pm by ghostsoldier
» 1966 Ford Mustang
Mon Nov 12, 2018 12:54 am by JAG
» RMS Titanic Control Room Panel
Sat Nov 10, 2018 1:43 pm by Bloodhound1958
» Donald M. Morgan/Dean Cundey
Thu Nov 01, 2018 3:22 am by Christinefan824
» Bettie wants to wish all of you and your Babies, a Happy Halloween!
Wed Oct 31, 2018 9:17 pm by Christopher L. Faddis Usn
 shifter cable leaking
grainger655
PostSubject: shifter cable leaking   Fri Mar 22, 2013 8:23 pm
i have a shiter cable leaking where it goes into the transmission is they a o ring or somthng there i may need to replace and if so where can i get one and what is it called other than a oring
chris beasley
PostSubject: Re: shifter cable leaking   Fri Mar 22, 2013 8:48 pm
Yes they are an o-ring goes on the adapter that goes into the tranny, I have alkways called it an o ring. I hate the cable shifers because most of them leak, My wife Eva has a 65 Plymouth , it has a cable colum shift. The cable leaks on it but it is in the housing itself. Smile
Now have you ever took your cable out of the tranny , It is sort of a trick in itself if you have never done it. Smile
[You must be registered and logged in to see this image.]
grainger655
PostSubject: Re: shifter cable leaking   Fri Mar 22, 2013 10:34 pm
yes i have had it out. do you know where i can find a o ring to fit it and how hard is it to replace
chris beasley
PostSubject: Re: shifter cable leaking   Fri Mar 22, 2013 10:46 pm
Cris I have some for the 1965 cables. Pm me your address and I will drop a couple in anenvelope and sent to you. No cost. Im sure they are the same ones.
Idaho Bob
PostSubject: Re: shifter cable leaking   Sun Mar 24, 2013 6:07 pm
The o ring is easy to replace......just slides on the shaft that enters the tranny. Not sure of the exact size but its written in the manual , I'll check it out and get back to ya!
PostSubject: Re: shifter cable leaking   Mon Mar 25, 2013 12:04 pm
The local parts store should have an o-ring that will work. Sometimes the leak is from the covering on the cable itself, if so, RTV silicon will work to seal it up.
PostSubject: Re: shifter cable leaking   Mon Mar 25, 2013 12:05 pm
Thats a common problem on these..
PostSubject: Re: shifter cable leaking   Mon Mar 25, 2013 12:21 pm
Chris as I told you in a PM I just sent, For some reason your Pm didn't show up on the Forum as it usally does when I firs log in. Sorry Smile I have just mailed you some out this morning. If you have got one from another sorce that is ok, Just keep these for spairs. :Idaho Bob:
grainger655
PostSubject: Re: shifter cable leaking   Mon Mar 25, 2013 12:24 pm
thank you bob i will be looking foward to recieving them
chris beasley
The Christine Car Club :: The Club House :: News & Announcements:-
