Today at 8:46 am by furvedere
 Would a 57 quarter panel work?
Ryuzaki27
PostSubject: Would a 57 quarter panel work?   Tue Mar 26, 2013 9:46 pm
Sorry for such a n00b question, but I'm still kind of fuzzy on which parts are interchangeable across which years and which body types, et al.
I found a right side lower quarter panel for a 57 Belvedere 4dr. Would that fit a 58?
Thanks!
http://www.facebook.com/d00fybatz
PostSubject: Re: Would a 57 quarter panel work?   Tue Mar 26, 2013 10:20 pm
You know I think so but you had better let one of the experts like Johnh Big M Wrecking answer He will know for sure. You have heard the old sayinhg they arn't any such thing as a dumb question. Well it applies here on the club Smile
PostSubject: Re: Would a 57 quarter panel work?   Wed Mar 27, 2013 1:42 am
The lower rear section should fit but of course the 57 and 58 holes for the body moldings are different so you would need to weld up and redrill for whichever car you have. so long as its a 4 door sedan qtr like yours it should be ok.
Ryuzaki27
PostSubject: Re: Would a 57 quarter panel work?   Wed Mar 27, 2013 2:14 am
Thanks for the info! The parts look identical as near as I can tell.
The primary difference to me is that I can locate a couple 57s. No luck at all with a 58 though. Some have said it's the same part, others say it's totally different. :/
PostSubject: Re: Would a 57 quarter panel work?   Wed Mar 27, 2013 2:43 am
i agree with Jase that it is the same but the molding trim holes will have a slightly different location
PostSubject: Re: Would a 57 quarter panel work?   Wed Mar 27, 2013 3:58 am
I think the only parts that dont really "interchange" are the fenders (different headlight buckets) and the stone pans up front. Obviously models dont interchange like 4 door hardtops to 4 door sedan quarters and coupe quarters or doors to sedan doors and quarters etc...
PostSubject: Re: Would a 57 quarter panel work?   Wed Mar 27, 2013 6:04 pm
The stamping itself is definitely the same, if an aftermarket panel, it will probably have no trim holes anyways. Be sure to check the fit if aftermarket, I have seen some that are a ways off from a good match.
Ryuzaki27
PostSubject: Re: Would a 57 quarter panel work?   Wed Mar 27, 2013 9:41 pm
I've seen a few "57-58 All models" aftermarket panels in a couple places. Black Car, eBay, et al.
Are they to be avoided?
PostSubject: Re: Would a 57 quarter panel work?   Fri Apr 26, 2013 12:52 pm
I used a lower quarter from a 4 dr on my 2 dr, and they matched up fine.
I got the quarter from Big M. Worked perfect. If you are doing the rockers, get the extra long ones that are available.
