Tue Sep 11, 2018 1:27 am by JAG
Thu Sep 06, 2018 9:51 pm by eva_392
Mon Aug 27, 2018 2:41 pm by Christinefan824
» Christine news
Mon Aug 20, 2018 12:42 am by Christinefan824
 Tightening Front Wheel Bearings
PostSubject: Tightening Front Wheel Bearings   Thu Mar 28, 2013 4:27 pm
I would like to find out your procedure on tightening the front wheel bearings on our cars...(basically any rear wheel drive car). I've heard many different methods...some of which I shake my head at but I'd like to go with a set plan once and for all. How do you guys do it? Thanks,
NYB
PostSubject: Re: Tightening Front Wheel Bearings   Thu Mar 28, 2013 7:24 pm
Roller bearing type wheel bearings as on our Mopars, all require A pre-load to function properly. Ball bearing type like used in late fifties and earlier GM products cannot be preloaded, or will fail prematurely.
When I had my repair shop business and when I taught high school auto shop, the recommended procedure was to snug the nut down, and then tighten to roughly 15 Lbs/ft. This will seat everything properly. Then back the nut off, rotate the drum [or disc], and then re-tighten, this time just putting a slight pre-load on the bearings, maybe 3-4 lbs/ft. I just do it by feel anymore after having done this for so many years. Be sure everything is kept sanitary, dirt in the grease can cause galling and premature wear.
PostSubject: Re: Tightening Front Wheel Bearings   Thu Mar 28, 2013 8:00 pm
Thanks John...I scoured the DeSoto service manual but could not find anything. It has to be in there. When I ask around I always seem to get a diffrent technique...probably because there should be for different makes...like you have mentioned. I'll follow your procedure.
What I've been doing up until now...is tightening the center nut just to where I can't feel any slop in the bearings when I rock the tire/wheel in/out (with my hands positioned at 12:00 and 6:00)
So it sounds like I've been leaving a bit too loose then.
NYB
cdasho
PostSubject: Re: Tightening Front Wheel Bearings   Thu Mar 28, 2013 11:07 pm
I tightened mine , turned the wheel then backed it off very slightly...turned the wheel again....Been Cherry ever since....I will keep an eye out now...
PostSubject: Re: Tightening Front Wheel Bearings   Fri Mar 29, 2013 10:11 am
That is exactly the way we did all our cars back in the 50's and 60's.
PostSubject: Re: Tightening Front Wheel Bearings   Fri Mar 29, 2013 10:14 am
What way Jim? You didn't quote anyone. Smile
NYB
PostSubject: Re: Tightening Front Wheel Bearings   Fri Mar 29, 2013 12:54 pm
I found a procedure in the 57-58 Plymouth Service Manual...I was looking in my DeSoto manual yesterday. It says while rotating wheel, tighten center nut to 90 inch/lbs. Then back lock nut up one notch to align lock nut to cotter pin hole. Would this 90 inch/lbs equate (divide by 12) to 7.5 ft/lbs? I do not have an inch/lb torque wrench...I only have a ft/lbs torque wrench. This would also put it into the same ballpark as what John said earlier.
NYB
PostSubject: Re: Tightening Front Wheel Bearings   Tue Apr 02, 2013 2:01 am
I agree with john..........Just remember to "pack' the bearings with really top notch high temp grease and I always renew the grease in the hubs before I put them on.
