 1957/58 sport coupe
Go to page : Previous  1, 2, 3, 4  Next
PostSubject: Re: 1957/58 sport coupe   Mon May 14, 2012 10:37 am
Arnie1964 wrote:
Nice set up Marc. I considered putting my set up from my 59 in my 58 but I have time to find the 58 set up.
Are you going to run a manual tranny Jim Smile
PostSubject: Re: 1957/58 sport coupe   Mon May 14, 2012 11:40 am
The vertigate will not work with the 833OD without tweaking, but its not hard. I did one years ago and promptly broke the trans. The aluminum cased 833OD doesn't stand up well to a big block if you beat on it at all. There is a rare iron cased version that is much tougher, or just swap the gears into an iron case.
IIRC, all you need to flip the 3-4 lever on the trans and fabricate a longer shift rod to reach the flipped arm.
PostSubject: Re: 1957/58 sport coupe   Mon May 14, 2012 11:58 am
Hey Rick you sound like you have been there done that, Thanks for the Info, I do not lie to shift myself but I still have to with my manuel valve bosy. Smile
PostSubject: Re: 1957/58 sport coupe   Mon May 14, 2012 12:30 pm
you really sound like you know what your talking about looking forward to seeing what you end up doing
PostSubject: Re: 1957/58 sport coupe   Fri May 18, 2012 5:40 am
I know the OD tranny in the '84 truck is cast iron. The regular A883 I have is a cast iron 1963 or so with a B&T tail. What to do....
PostSubject: Re: 1957/58 sport coupe   Sun May 20, 2012 4:56 pm
Vertigate mockup pictures:
PostSubject: Re: 1957/58 sport coupe   Sun May 20, 2012 6:51 pm
Hey Marc, Dude tha look's Bada**!!!! Very nice. Nice cutting work around the tunnel area.
PostSubject: Re: 1957/58 sport coupe   Sun May 20, 2012 7:18 pm
It will look even better when I clean it up and weld those gaps. Now where is my MIG?
PostSubject: Re: 1957/58 sport coupe   Sun May 20, 2012 8:36 pm
Hee! Hee! Sounds like Me mark if it can be misplaved I can do it. Smile
PostSubject: Re: 1957/58 sport coupe   Mon May 21, 2012 12:58 am
looking good Marc, ive never used one of these shifters before but i always thought they looked bad to the bone Laughing
PostSubject: Re: 1957/58 sport coupe   Mon May 21, 2012 1:38 am
Great work Marc I know its always tough to locate where the shifter will be then cutting floor to correspond , Are you building your GC 350 mild or wild?
PostSubject: Re: 1957/58 sport coupe   Mon May 21, 2012 6:13 am
I know you waited quite a while to finally get a HT. Nice to see you getting her put together the way you want. Great work.
PostSubject: Re: 1957/58 sport coupe   Mon May 21, 2012 11:23 am
Can't wait to see more.
PostSubject: Re: 1957/58 sport coupe   Mon May 21, 2012 11:37 am
Great Shifter Marc , Lots were used at the racetrack , some are still used . Smile
PostSubject: Re: 1957/58 sport coupe   Tue May 22, 2012 7:45 am
Just catching up on your work Marc. Your door panels are going to look great. I see you have one of the same books I used for reference. And your putting in a floor shifter. Don't remember ever seeing one like it. Cool Cool I'm trying to figure out where to put mine. Is there a reason for not putting it in the center of the hump??? scratch
PostSubject: Re: 1957/58 sport coupe   Tue May 22, 2012 1:18 pm
You're a wise man, Marc, for mocking everything up before doing the actual restore work.
I've seen many nicely restored cars go back to the drawing board after painting, finding that things do not fit or modifications don't allow something.
PostSubject: Re: 1957/58 sport coupe   Tue May 22, 2012 2:45 pm
I agree with you John Marc is a smart person, Whatever you can build yourself saves you money. Even at my age I have more time then money, I think Hee! Hee!
PostSubject: Re: 1957/58 sport coupe   Tue May 22, 2012 5:35 pm
Well, This is a Straight Line shifter and mounts to the side of the 4 speed manual transmission. There are shifters like inland factory shifters from volare's etc. that move the handle closer to the center of the hump and goes around bench seats. Hurst makes some too that will work with bench seats and may have interchangable handles. If you want a tall one, get one out of a 1984 or so truck with an A833 tranny. Marc. P.S. something like this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180889333506&ssPageName=ADME:B:SS:US:1123
http://www.ebay.com/itm/1968-340-383-Body-Cuda-Inland-Shifter-Link-833-4-speed-Mopar-/330735948551?_trksid=p4340.m263&_trkparms=algo%3DSI%26its%3DI%252BC%26itu%3DUCI%252BUA%252BFICS%26otn%3D15%26pmod%3D180889333506%26ps%3D63%26clkid%3D8604416723665010904
http://www.ebay.com/itm/Factory-Mopar-Hurst-4-Speed-Shifter-Linkage-OEM-Charger-Ram-Dodge-Plymouth-/150818253627?_trksid=p4340.m503&_trkparms=algo%3DRIC.CFNP%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D330735948551%26ps%3D63%26clkid%3D8604421309346061393
http://www.ebay.com/itm/HURST-MOPAR-DODGE-4-SPEED-SHIFTER-1965-1970-B-BODY-W-CONSOLE-NEW-PROCESS-833-/300675334581?_trksid=p4340.m263&_trkparms=algo%3DSI%26its%3DI%252BC%26itu%3DUCI%252BUA%252BFICS%26otn%3D15%26pmod%3D180889333506%26ps%3D63%26clkid%3D8604435360715505241
http://www.ebay.com/itm/67-Plymouth-GTX-4-speed-console-shifter-handle-Mopar-/300705532187?hash=item460372491b&item=300705532187&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr
PostSubject: Re: 1957/58 sport coupe   Tue May 22, 2012 11:54 pm
great to know Marc nice job mocking everything up like John and Bob already pointed out
PostSubject: Re: 1957/58 sport coupe   Fri Jun 01, 2012 9:21 pm
Did a little welding saturday, fixing mistakes:
PostSubject: Re: 1957/58 sport coupe   Fri Jun 01, 2012 9:47 pm
Hi great work Marc .Looks Clean. Smile
PostSubject: Re: 1957/58 sport coupe   Fri Jun 01, 2012 10:41 pm
looks good marc is that a tig weld or mig weld?
PostSubject: Re: 1957/58 sport coupe   Sat Jun 02, 2012 6:34 am
Great work Marc. I know you waited a long time to get your HT so now it must be a real p[leasure working on it.
PostSubject: Re: 1957/58 sport coupe   Sat Jun 02, 2012 7:59 am
Yes! It is flux core mig welding. If I were to do it again I would have made a new piece and overlapped the two. Marc
PostSubject: Re: 1957/58 sport coupe   Sat Jun 02, 2012 5:35 pm
you did a nice job i am still in the learning process of mig welding
PostSubject: Re: 1957/58 sport coupe   Wed Jun 13, 2012 7:18 pm
Tach. drive repair: Oh look the gear pin sheared, no tachy!
Found most parts at ACE Hardware:
She will be better soon!
I found the Dizzy on the 'pay for $57! Caint complain. Marc. Oh yeah, I got some clutch parts too!
PostSubject: Re: 1957/58 sport coupe   Thu Jun 14, 2012 12:17 am
looks like you got some nice parts there
PostSubject: Re: 1957/58 sport coupe   Sat Jun 16, 2012 1:12 pm
I collected up some gauges that seem to fit with our instruments.
I plan on fitting these in the instrument panel and an under dash diamond S&W panel.
PostSubject: Re: 1957/58 sport coupe   Sat Jun 16, 2012 1:28 pm
cool Cool
PostSubject: Re: 1957/58 sport coupe   Sat Jun 16, 2012 2:36 pm
Awesome gauges.
1957/58 sport coupe
Page 3 of 4Go to page : Previous  1, 2, 3, 4  Next
The Christine Car Club :: Members Rides, Restorations & Pictures :: Members Rides :: 1957-58 Plymouth-
