Posts : 54 Points : 66 Reputation : 0 Join date : 2013-06-16 Age : 36
Subject: Car pulling to the right. Sat Jun 22, 2013 2:57 pm
As the title says, when im driving... i must turn near half turn to the left for going straight, and if i let go, the car just when to jump outside of the word. At first i though itjust about an alignment but my wife told me it smell fussy in that Wheel (i lost the sense of odor ... ) so i think is because the brake is always braking. What can cause this, a bad Master ? i dont think so beacause the other Wheel look good... can it be bad hose ? or it,s just a bad adjustement of brake ? i'm asking you for clue please...And second hint i need, is those front drum need the puller i saw in other trhead? the one BIG M put in photo ?
(hope my English is enough understandable...Grrr !)
JAG Administrator
506/ 505hp Viper V10 2015 Posts : 5141 Points : 5132 Reputation : 4 Join date : 2011-11-18 Age : 32 Location : Syracuse NY
Subject: Re: Car pulling to the right. Sat Jun 22, 2013 9:48 pm
could be a bad wheel cylinder, i dont think a master cylinder would cause that. better wait for another opinion from another member
Subject: Re: Car pulling to the right. Sun Jun 23, 2013 7:00 am
You should not need any type of drum puller to pull the front drums. Back off on the adjuster a little and see if that stops it. If not pull the drum and check the brake shoes on that side. If she pulls to the right the right front brake shoes may be too tight or contaminated with brake fluid from a wheel cylinder leak.
Bosniak CCC Member
Subject: Re: Car pulling to the right. Mon Jun 24, 2013 10:11 am
Ok, i will start by that... Thanks arnie
Bosniak CCC Member
Subject: Re: Car pulling to the right. Sun Jul 21, 2013 2:13 pm
I have updates, the light problem solved, I have an issue with brake lights, ... More brake issue, my stop light is always on, when I remove the sensor from the master, it goes off, then, if I put it back and push the brake again, it's stay on,... Why do I have pressure in my lines when I release the brake pedals? From my view, the problem is in the master... But you are the pros here...
Bosniak CCC Member
Subject: Re: Car pulling to the right. Sun Jul 21, 2013 2:18 pm
And when I press the pedal with the master cover removed, it spray brake fluid out side the reserve
Bluebird57 CCC Member
Posts : 54 Points : 80 Reputation : 0 Join date : 2012-02-22 Age : 42 Location : MN
Subject: Re: Car pulling to the right. Fri Dec 02, 2016 6:50 am
I just got off of the brake problems roller coaster. I hope you find a good solution. If the stop light switch doesn't work give it a whack with the end of a wrench. worked for me. just a bubble or something I think
furvedere CCC Chaplain
ELITE GOLDEN COMMANDO CONTRIBUTOR 2014 Posts : 2405 Points : 3266 Reputation : 4 Join date : 2012-10-12 Age : 58 Location : Ontario, NY
Subject: Re: Car pulling to the right. Fri Dec 02, 2016 9:41 am
A brake puller is needed for rear brakes only. Sounds like it's time...to take the front brake drums off and inspect inside to see whats going on. First though...once car is up in the air spin the wheels by hand...and I'm thinking the right wheel should not "free wheel" at all.
It is kind of strange though, that WITHOUT braking, the car pulls to the right. I would expect it to be a brake related problem if the car pulls to the right AFTER you hit the brakes. If it is a brake related problem, it should be very obvious once you get in there...leaking wheels cylinders...fluid all over the shoes etc...
_________________ 1958 DeSoto Firesweep 2 dr ht 1958 Plymouth Belvedere 2 dr ht 1968 Plymouth Fury III
And this is the testimony: God has given us eternal life, and this life is in His Son. He who has the Son has life, he who does not have the Son of God does not have life. 1 John 5:11-12
58belvedere CCC Member
Beefed up 350 Golden Commando Posts : 1359 Points : 2465 Reputation : 1 Join date : 2011-11-06 Age : 58 Location : Texas
Subject: Re: Car pulling to the right. Fri Dec 02, 2016 7:01 pm
I would rebuild the wheel cylinder or replace it at a minimum. The hoses can have internal defects keeping pressure in that wheel cylinder, change it. Cheap insurance to keeping ALIVE!. Marc.
_________________ She'll start; You'll need these...
