 front drum removal
PostSubject: front drum removal   Fri Dec 23, 2011 12:50 am
I tried loosening the lugnuts on my front brake drum and it won't loosen for the life in me. Is the stud turning when I turn the lugnut or what? It is the tightest lugnuts I have ever dealt with. Any ideas to what is going on?? Over torqued with a air gun?
PostSubject: Re: front drum removal   Fri Dec 23, 2011 8:36 am
Steve, Now on the early Mopars one side is reversed threads, All my cars have been changed ovet to right but I don't know which is which, I know Big M or somebody will be on here a little later to tell you. So what you might be doing is tightening instead of loosening. Smile
PostSubject: Re: front drum removal   Fri Dec 23, 2011 9:19 am
Left hand side, left hand thread. Bet there real tight by now!!!
PostSubject: Re: front drum removal   Fri Dec 23, 2011 2:01 pm
OH boy, I am glad to get help on this! THANK YOU for the info guys. I have never owned a vehicle that had this kind of setup or even ran into anything siimilar. At least I can quit trying
to turn them the wrong way and actually save myself from breaking my arm or tools! Razz
PostSubject: Re: front drum removal   Fri Dec 23, 2011 4:47 pm
Sort of thought that was the problem, I have an updated rear end and disc brakes so everything I have now are right handed. I like it like that Smile
front drum removal
