Yesterday at 8:05 pm by Bloodhound1958
 What is the tallest tire you can run?
PostSubject: What is the tallest tire you can run?   Sun Aug 11, 2013 9:22 pm
Like the title says i was wondering what is the tallest tire you can run in the front without having clearance issues when turning or bottoming out?
thanks
PostSubject: Re: What is the tallest tire you can run?   Tue Aug 13, 2013 12:42 am
does 27" sound about right to everyone?
[You must be registered and logged in to see this image.] [You must be registered and logged in to see this image.]
PostSubject: Re: What is the tallest tire you can run?   Tue Aug 13, 2013 6:26 am
Really don't know Joe. I never tried putting any oversized tires on my car. Maybe some one will pipe in that has.
PostSubject: Re: What is the tallest tire you can run?   Tue Aug 13, 2013 12:04 pm
Not sure what the biggest tire size that will clear, Joe, but the largest tires available from the factory were 800 14's. these were standard on Furys only. Other models used the lower profile 750 14's.
PostSubject: Re: What is the tallest tire you can run?   Tue Aug 13, 2013 4:53 pm
Back in the day when I was a young man I was running 9:50X15 on 57. I couldn't tell you what the modern day equivelent is. I had converted to new yorker drums and wheels all around
Christine's Back
GRANDMASTER OF THE KNIGHTS ORDER OF THE CCC
PostSubject: Re: What is the tallest tire you can run?   Tue Aug 13, 2013 8:31 pm
Joe I will get some measurements for you. I used to have some bigger wheels and tires on my car til I want to the wide whites. What exactly do you want overall height or wideth
PostSubject: Re: What is the tallest tire you can run?   Tue Aug 13, 2013 11:25 pm
i want to be able to run a 27" tire because i want to run 17" rims and i dont want low pro tires
Christine's Back
PostSubject: Re: What is the tallest tire you can run?   Sun Aug 18, 2013 3:20 pm
Hey Joe. The 17's I had on my car were 245/45/17 on the fronts and 275/45/17 on the back. And mine was lowered . I never had any issues . I could have gone a little taller if I wanted too.
PostSubject: Re: What is the tallest tire you can run?   Sun Aug 18, 2013 7:56 pm
thats great walt that is about what i will be getting
The Christine Car Club :: Non Automotive Off Topic Section :: General Discussion/World News & Off Topic Section-
