 rear seat removal
PostSubject: rear seat removal   Tue Jun 17, 2014 1:38 am
Hey guys, could someone tell me how to remove the rear seat from my 57 coupe?
PostSubject: Re: rear seat removal   Sat Jun 21, 2014 11:58 am
You need to push the front of the bottom seat cushion inward's and then upward's all in one motion, nothing to unscrew up to this point. After that all screws for the back seat cushion and arm rests are exposed.
PostSubject: Re: rear seat removal   Sun Jun 22, 2014 10:14 pm
Thanks Andy!
PostSubject: Re: rear seat removal   Mon Jun 23, 2014 9:52 am
Yep...that's perfect advice. A few times I've struggled with removing back seat bottom cushions (if they've been in place a long time). But pushing at the bottom of the bottom cushion towards the back of the car and then lifting up should do it. There's 2 "hook points"...and I believe they're located approx. in the center of each rear floor pan. Once you get the cushion out, you'll see what a nice fastening method this is. Oh, and I always forget this myself...Rear Armrests should be unscrewed/removed first for easier removal of bottom cushion.
PostSubject: Re: rear seat removal   Tue Jun 24, 2014 12:27 am
Thanks Bob, John (Big M) gave me good info too! I'm glad we have a place like this to get help with our projects. One question, doesn't the seat have to be removed first in order to remove the arm rests on a coupe?
PostSubject: Re: rear seat removal   Tue Jun 24, 2014 1:03 am
you should be able to get to the screw holes for the rear armrest before removing the bottom portion of the seat
PostSubject: Re: rear seat removal   Tue Jun 24, 2014 11:34 am
I may be wrong but the crews of the arm rests are not visible. Maybe if you remove the carpet, I don´t know. I´m pretty sure I first removed the bottom, then the top cushion and at last the arm rests.
PostSubject: Re: rear seat removal   Tue Jun 24, 2014 10:22 pm
Thanks guys, I'm gonna have to do some investigating. :study:
PostSubject: Re: rear seat removal   Wed Jun 25, 2014 12:34 am
well i wouldnt know my car was in bad shape with no arm rest or back seat Very Happy
PostSubject: Re: rear seat removal   Sat Dec 13, 2014 11:06 pm
Im thinking my rear bottom seat has never been out! Tried to remove it today..and as you guessed it...It was a NO GO! ha ha . I will have to try a few of these ideas tomorrow.
PostSubject: Re: rear seat removal   Sun Dec 14, 2014 12:05 am
are you familiar how to remove the seat Brian? No offense Very Happy
PostSubject: Re: rear seat removal   Sun Dec 14, 2014 7:38 pm
Ha Ha no worries Joe! no offense taking at all! Very Happy Im not at all familiar with the removal of the rear bottom seat. Ive done restorations and such but this has me a bit baffled. But ive got some help from Chris and also reading on here. I was just curious to see how bad it was under the rear seat.  Im almost sure some varmints  have nested under there. Not to mention just being in the car gives me the weebee geebees! ha ha
Brian. santa
PostSubject: Re: rear seat removal   Mon Dec 15, 2014 3:21 am
I didn't even realize until now you posted in Chris old thread. They are a pain at first but once you figure out how it works it is much easier. You need to actually stand in the back seat footwell facing the trunk. Bend down and push your knees and use your hands pushing on the front part of the bottom section of the back seat. One side at a time. Passenger side and drivers side. Once you remove it take a good look underneath and you will realize how it works. No tools needed for this job unless the armrest are in the way? Hope this helps Brian
PostSubject: Re: rear seat removal   Mon Dec 15, 2014 9:40 pm
No worries Joe, After taking your advice and Chris giving me advice and seeing what Bob said woolah! I got it out. The key is to pop one side out at a time. I was trying to get it all out at once. But now I see how this works! Thanks guys! Oh yah I almost for got.. I did find some goodies under that seat. Some good and some bad! ha ha maybe I should of left it in! Very Happy
Brian. santa
PostSubject: Re: rear seat removal   Mon Dec 15, 2014 10:19 pm
We need details of all the little bits that were under there! :affraid:
PostSubject: Re: rear seat removal   Mon Dec 15, 2014 11:47 pm
i agree i also want to know what was under there
PostSubject: Re: rear seat removal   Tue Dec 16, 2014 12:31 pm
I get any money that was found! LOL!
Most money I ever found in a car was a $100 bill that was wadded up and stuffed under a console in a '63 Galaxie X/L, along with a few hundred Doublemint gum wrappers.
PostSubject: Re: rear seat removal   Tue Dec 16, 2014 1:04 pm
At least it wasn't $100 in pennies! Smile
PostSubject: Re: rear seat removal   Tue Dec 16, 2014 2:48 pm
Ha Ha well I didn't find a $100 but I did find some change! Heres the break down so far!
1) fan belt
2) radiator cap
3) couple spark plugs
4) Old car freshener(no longer freshening)
5) Large Rat/mouse nest (nasty huge)
6) Couple old bottle caps (Grapette. Never heard of that)
7) My favorite.. RUST!
That's the list so far but im sure I will find more as I clean and dig through this nasty stuff! ha ha lol
Ill keep yah posted!
Brrian.santa
PostSubject: Re: rear seat removal   Wed Dec 17, 2014 11:17 am
I still want photos Brian!!
Laughing Bob
PostSubject: Re: rear seat removal   Wed Dec 17, 2014 11:23 am
I remember Grapette pop! Haven't heard of that in a long time.
PostSubject: Re: rear seat removal   Wed Dec 17, 2014 4:13 pm
Was it good stuff John?
Brian. santa
PostSubject: Re: rear seat removal   Wed Dec 17, 2014 4:52 pm
It was pretty much like Nu-Grape, Faygo, or any other grape soda that was available then. Good, but nothing to write home about.
PostSubject: Re: rear seat removal   Thu Dec 18, 2014 12:05 am
Brain as the 1st LIEUTENANT OF THE KNIGHTS ORDER OF THE CCC i DEMAND that you take lots of progress pictures of your car and start a new thread in the restoration section, i dont care if its a picture of a mouse turd we all want to see it. Got it? Razz
PostSubject: Re: rear seat removal   Thu Dec 18, 2014 1:04 am
Uh oh Brian, you've been told! lol!
Christine's Back
GRANDMASTER OF THE KNIGHTS ORDER OF THE CCC
PostSubject: Re: rear seat removal   Thu Dec 18, 2014 6:59 am
Oh yeah , WE love pictures. I can't read so I depend on the pictures to know what is going on. lol
PostSubject: Re: rear seat removal   Thu Dec 18, 2014 7:17 pm
Ha Ha lol! I will make sure I start a restoration thread! And take pics of everything! You guys really crack me up! Too funny! Very Happy
Brian. santa
rear seat removal
