Tue Sep 11, 2018 1:27 am by JAG
Thu Sep 06, 2018 9:51 pm by eva_392
Mon Aug 27, 2018 2:41 pm by Christinefan824
» Christine news
Mon Aug 20, 2018 12:42 am by Christinefan824
 Dropped spindle kit from Fat Man
PostSubject: Dropped spindle kit from Fat Man   Sat Apr 04, 2015 5:16 pm
http://www.fatmanfabrications.co/products/1957-1988-mopar-dropped-spindles/
At Fatman Fabrications we only manufacture and sell the best 1957 – 1988 Mopar Dropped Spindles that you will find anywhere. These heavy-duty 2” Mopar Dropped Spindles will accept the stock Mopar ball joints and tie rod ends. We’ve done the work to improve the revised outer tie rod end position, which was necessary for bumpsteer reduction into the weld fixture.
The torsion bars can be put back to a practical ride height, improving ride and handling without sacrificing stance. These 1957 – 1988 Mopar Dropped Spindles fit most Mopar Frames, but simply Contact Us and we will be sure to get you the right Mopar Dropped Spindles specific to your vehicle!
The Fatman Fabrication Mopar Dropped Spindles are specifically manufactured for your 1957 – 1988 Mopar Original Suspension. Once you have the right parts from us you will be able to bolt your Mopar Dropped Spindles right on and simply reinstall your own or upgraded Disc Brake Kits.
Price: $525.00 (pair)
Additional things well need to know:
•We will need to know the exact year of your Mopar
•Whether vehicle has manual or power steering
Upgrade Options
•NEW Iron Brake Parts
•11” Wilwood Rotors & Calipers
•11” Wilwood Drilled Rotors & Calipers
•12” Willwood Rotors & Calipers
•12” Wilwood Drilled Rotors & Calipers
•13” Wilwood Rotors & Calipers
•13” Wilwood Drilled Rotors & Calipers
Call or Contact Us to order your 1957 – 1988 Mopar Dropped Spindles today!!!
704-545-0369
The Christine Car Club :: Christine Car Club Tech Section :: Steering and Suspension:-
