 What happened to the host image box?
PostSubject: What happened to the host image box?   Tue Mar 08, 2016 8:52 pm
I tried hosting images and the box has changed, and I can't navigate through it.
PostSubject: Re: What happened to the host image box?   Tue Mar 08, 2016 9:56 pm
[You must be registered and logged in to see this image.]
Seemed to work for me... My photo of a '57 Fury showed up, right? And yes I did notice the host image box has been changed. So let me see if I can try to help you out Chris. What I did is click on host image, the box appears, and up at the top of the box you see a smaller rectangular box with drop your files here or select files. I clicked on select files to upload a photo saved onto my computer. Selected a photo from my computer. Now I clicked on a blue box beside the uploaded photo. Then I saw a green bar as it was uploading the photo. Then I saw 3 links to choose from. I copied the first one. If you hover your mouse over the icon to the left of it, it says image links. This is the one I selected. Now go to insert image, and paste the link inside of the URL box. Insert. The photo should now appear in your reply. This is how I did it. Hope this helps. Smile
PostSubject: Re: What happened to the host image box?   Tue Mar 08, 2016 10:06 pm
Now you can drag files from your desktop and "drop" them into the box. Always select the first code on top for the forum. Then click on the insert image box and paste in the code. Click send and your good to go! Smile
PostSubject: Re: What happened to the host image box?   Tue Mar 08, 2016 10:21 pm
Wayne, does using the "select files" one right nest to the "drop your files here" work just as good? Why I ask is because my computer doesn't seem to like me to drag files from the desktop and drop them into the box. I used the method of selecting the files instead of dropping them above in my reply. Did that photo appear, or am I the only one who's seeing it?
ArnieCunningham
PostSubject: Re: What happened to the host image box?   Tue Mar 08, 2016 11:42 pm
Now i wanna test it out. Laughing
[url=http://www.servimg.com/view/16294878/33][You must be registered and logged in to see this image.][/url
Arnie Cunningham: Well, isn't that what you're supposed to do with sh*t Scrape it up with a little shovel?
Arnie Cunningham - All of this because some drunk ran over that sh*tter Welch?
Arnie Cunningham -  you just saddle up and ride along with all those other  sh*tters.
Arnie Cunningham - 'Ung-ung-gooth-ung,'
[You must be registered and logged in to see this image.] [You must be registered and logged in to see this image.][You must be registered and logged in to see this image.]
PostSubject: Re: What happened to the host image box?   Tue Mar 08, 2016 11:58 pm
im seeing everyones photos
PostSubject: Re: What happened to the host image box?   Wed Mar 09, 2016 6:58 am
Either way of doing it works the same Jackie. Smile
PostSubject: Re: What happened to the host image box?   Wed Mar 09, 2016 12:25 pm
Thanks guys, My trouble was I couldn't see the right side of the box, it was cut off so I couldn't scroll down to see the pics but it's working now.
PostSubject: Re: What happened to the host image box?   Wed Mar 09, 2016 3:24 pm
Ok, thanks very much for answering my question Wayne. Glad it works either way, cause my computer doesn't seem to allow me to do it the first way of dragging and dropping the photos. So again. glad to hear it works the second way just as well as if I were to do it the first way. Smile
ozoner
PostSubject: Re: What happened to the host image box?   Fri Mar 11, 2016 8:20 pm
This is good to Know for future postings. I used Photo bucket.
ArnieCunningham
PostSubject: Re: What happened to the host image box?   Sat Mar 12, 2016 2:08 am
Tiny pic I use.
PostSubject: Re: What happened to the host image box?   Sat Mar 12, 2016 2:53 pm
WOW! The bulk upload feature works great! Follow these instructions to try it out...
1.) Select "Host An Image" box..
2.) Click "Select Files" and browse to the folder or destination where the pics are you want to post.
3.) Highlight the photos and select "Send All".
4.) Then click on "Insert All" and the codes will automatically post in the message body of your post. No more copying and pasting the code yourself! cheers
You can then type what you want before or after the picture codes before you click send! Smile
PostSubject: Re: What happened to the host image box?   Sat Mar 12, 2016 5:17 pm
Cool beans!
The Christine Car Club :: Non Automotive Off Topic Section :: General Discussion/World News & Off Topic Section-
