 What Are these trans called... idk! Please help....
IcyPolar
PostSubject: What Are these trans called... idk! Please help....   Fri Apr 01, 2016 12:05 am
Ok please excuse me if this sounds outrageously stupid but what are these two transmissions called
First one
It has 4 buttons and I believe they are Drive, Neutral, Reverse, and Low Range Gears. I still don't know what there called
http://illiweb.com/fa/pbucket.gif
Second one
I believe these were called The TorqueFlite transmission (still not sure) I believe they used these on Furys cause they were more performance based.
Thank you any infor would be helpful again in sorry if I sound really damn stupid in just not sure and I want to know.
Sean
PostSubject: Re: What Are these trans called... idk! Please help....   Fri Apr 01, 2016 5:27 am
Few changes were made under the hood-the PowerFlow Six struggled on for one more year, developing 152hp at 3600rpm. The base V-8 was the Fury V-800, a 31Sci 225hp two-barrel which was standard on all models except the Fury. Like its four-barrel cousin, the Fury V-800 with Super Pak (250hp) could be mated to the straight-stick transmission (with or without overdrive), PowerFlite, or three-speed TorqueFlite. The Dual Fury V-800, also a 318 but with 9.25:1 compression and dual four-barrel carburetors, was exclusive to the Fury and could be mated only to the standard transmission without overdrive or TorqueFlite.
http://www.allpar.com/history/plymouth/1946-1959/cars-1958.html
Marc.
PostSubject: Re: What Are these trans called... idk! Please help....   Sun Apr 03, 2016 8:54 pm
4 button automatic (R, N, D, L) = powerflite
5 button automatic (R, N, D, 1, 2) = torqueflite
