 Mounting Carter dual quad air cleaners on edelbrocks help
58 Detroit
PostSubject: Mounting Carter dual quad air cleaners on edelbrocks help   Thu Apr 21, 2016 7:46 pm
Hi everyone! I am trying to attach a pair of original carter 2x4 air cleaners to a pair of edelbrocks. I tried the mr gasket air cleaner adapters in reverse but that will not work. Any ideas? I am not interested in cutting or altering my factory air cleaners. There must be a adapter or something, I have seen pics but just not sure what was used. Thanks in advance!
PostSubject: Re: Mounting Carter dual quad air cleaners on edelbrocks help   Thu Apr 21, 2016 8:06 pm
In this case you have to make your own bases or customize the originals. My plan is to buy 2 large aftermarket air cleaners with large flat bases. From there I'm going to cut out the oval shape and go from there. I was also thinking about taking the original bases and enlarging the openings with these. All trial and error unfortunately..
http://www.amazon.com/Allstar-Performance-ALL26086-Cleaner-Spacer/dp/B003BZX0SK
58 Detroit
PostSubject: Re: Mounting Carter dual quad air cleaners on edelbrocks help   Thu Apr 21, 2016 8:30 pm
Thanks, I was just looking at those spacers too. I am thinking that should go over and against the factory carter base without modifications, as long as it is not making the air cleaners sit too high for hood clearance, I think I will try the spacers and report back! Thanks!
