 How To Route Belts.. 350 GC with A/C
PostSubject: How To Route Belts.. 350 GC with A/C   Sun Jun 05, 2016 8:28 pm
I don't know if I'm getting "old timers" disease or if I'm just plain stupid but I can't seem to figure out how to route the belts on my motor. I have a 350 GC with air...
Now, I have a 3 groove crank pulley. The fan/water pump pulley lines up with the crank pulley closest to the block. The A/C compressor and generator are both dual pulley and there's the power steering pump to consider. Any idea as to how they should be run?
PostSubject: Re: How To Route Belts.. 350 GC with A/C   Sun Jun 05, 2016 8:58 pm
Here is a pic of a typ mopar bigblock with a/c.
PostSubject: Re: How To Route Belts.. 350 GC with A/C   Sun Jun 05, 2016 9:29 pm
Uh Oh... Is that a 4 groove crank pulley? I aint got no stinking 4 grooves mang..
Here's a 350 GC with air. Can't see well enough to decipher how the belts are run though. Sad
PostSubject: Re: How To Route Belts.. 350 GC with A/C   Tue Jun 07, 2016 8:45 am
Judging by the above picture, There are two belts that run from the 2 grooves closest to the block on the crank pulley to both the Generator and AC compressor. The power steering belt then runs to the outer most groove on the crank pulley to the water pump above. So, that means I have the wrong stinking fan pulley as mine aligns with the groove closest to the block.
Still, in the above picture it doesn't look to me like the belt on the power steering pump angles up to the water pump pulley.. scratch
PostSubject: Re: How To Route Belts.. 350 GC with A/C   Sun Jun 19, 2016 3:59 pm
http://syracuse.craigslist.org/pts/5616470983.html
PostSubject: Re: How To Route Belts.. 350 GC with A/C   Sun Jun 19, 2016 7:21 pm
Interesting Marc. Is a 413 the same "block" as the 350? Parts may be interchangeable...
PostSubject: Re: How To Route Belts.. 350 GC with A/C   Sun Jun 19, 2016 7:35 pm
It is a raised deck block...RB  Brackets should be the same 'cept for heads are a little higher.  Marc.
Some info:
http://www.dodgecharger.com/forum/index.php?topic=99245.0
PostSubject: Re: How To Route Belts.. 350 GC with A/C   Sun Jun 19, 2016 7:44 pm
I could REALLY use the power steering pump.. if it lines up with the 3rd outer groove on the crank pulley. I wonder if NY Bob might have a use for anything off of it. I guess I'll have to make a call or two. Smile
