  Electronic Distributor with 301ci
Jurrasic car
PostSubject: Electronic Distributor with 301ci   Mon Nov 20, 2017 5:22 pm
Hi,
I have a 1957 plymouth belvedere.
here is his engine : Chysler A engine / 301ci (The Plymouth 301 replaced the 278 in 1957).
it's compatible with this distributor ? :
https://i62.servimg.com/u/f62/15/82/04/24/s-l16011.jpg
Thank you
Cheers
PostSubject: Re: Electronic Distributor with 301ci   Tue Nov 21, 2017 1:24 am
From what I've read, any distributor that fits the LA small block mopars should work with the poly engines.
PostSubject: Re: Electronic Distributor with 301ci   Tue Nov 21, 2017 5:51 am
I put a cheapie 318 LA hei style in my 301 and it fit and worked. Marc.
Jurrasic car
PostSubject: Re: Electronic Distributor with 301ci   Tue Nov 21, 2017 3:58 pm
Good  Very Happy
so for the distributor a Chrysler A = LA, it's the same ^^
I was scared because the seller wrote me this:
"Thanks for your question,
This distributor is designed for the Chrysler LA engine. Some sources show that the distributors will interchange with the A engine. Using this distributor in your enging is at your own risk.
Thanks,
Paul"
Thank you guys, I'll be able to take this distributor with the coil
I'm talking about this too but it's more expensive and less efficient:
"PerTronix 1383 Ignitor Points Eliminator Kit, 1951-58 Mopar V8"
Thank you for your help
Jurrasic car
PostSubject: Re: Electronic Distributor with 301ci   Tue Nov 21, 2017 4:03 pm
in fact, she also thanks you  Smile
Jurrasic car
PostSubject: Re: Electronic Distributor with 301ci   Sun Feb 04, 2018 2:45 pm
it works, there is very little space
we did not tweak the settings
PostSubject: Re: Electronic Distributor with 301ci   Mon Feb 05, 2018 3:14 am
Nice! Sounds pretty happy at idle.
Jurrasic car
PostSubject: Re: Electronic Distributor with 301ci   Mon Feb 12, 2018 6:34 am
thank you
I will also change the engine and carburetor seals cheers
