 BRAKE LAMP SWITCH LOCATION?
GOREDFURY
PostSubject: BRAKE LAMP SWITCH LOCATION?   Sat Nov 25, 2017 12:40 pm
SO TELL ME IF I'M THE ONLY ONE, IT SEEMS THAT HYDRAULIC BRAKE LAMP SWITCH IN MY MASTER CYLINDER BURNS OUT AT LEAST TWICE A YEAR. I'VE HEARD OTHERS TALK HOW THEY WERE PROBLEMATIC BUT THIS SEEMS EXCESSIVE. NOW I HAVE NON POWER ASSIST MASTER CYLINDER, SHOULD THIS SWITCH BE SCREWED INTO THE ENDOF THE MASTER OR ON THE BOTTOM PORT LIKE MINE ALREADY IS? I'VE SEEN THE CONVERSION KITS FOR A SWITCH ON THE BRAKE PEDAL, ID LIKE TO JUST KEEP THINGS SIMPLE AND ORIGINAL, BUT I AM TIRED OF REPLACING THIS SWITCH.
1958 SAVOY
"WELL SHE CAN BE FIXED UP, SHE COULD, BOY SHE COULD BE REALLY TOUGH"
PostSubject: Re: BRAKE LAMP SWITCH LOCATION?   Sat Nov 25, 2017 4:44 pm
That switch should not burn out that quickly or that often. Sounds to me like it's an electrical issue as opposed to the hydraulic/electric switches themselves. If you want to get really in depth you could check your wiring and grounds. I'd put an inline fuse in going to the switch and add a ground wire. That should fix the issue. Have you checked to see how dirty the brake fluid is? Chunks of crap can get into the switch and make it malfunction as well.
GOREDFURY
PostSubject: Re: BRAKE LAMP SWITCH LOCATION?   Sun Nov 26, 2017 10:55 am
WHAT ABOUT THE SWITCH LOCATION? IS YOURS ON THE BOTTOM OR THE END OF THE MASTER CYLINDER?
1958 SAVOY
PostSubject: Re: BRAKE LAMP SWITCH LOCATION?   Sun Nov 26, 2017 11:28 am
Mine is on the end.
PostSubject: Re: BRAKE LAMP SWITCH LOCATION?   Sun Nov 26, 2017 11:40 am
Mine was on the bottom on the original master cylinder.
GOREDFURY
PostSubject: Re: BRAKE LAMP SWITCH LOCATION?   Sun Nov 26, 2017 2:30 pm
WELL THATS GOOD TO KNOW, WHAT SEEMS TO BE HAPPENING TO MINE IS BRAKE FLUID ACTUALLY GETTING INSIDE OF THE ELECTRONICS, GUESS NEXT TIME ILL SEE IF I CAN FIND A BETTER MANUFACTURER OF THE SWITCH
1958 SAVOY
