Sun Jan 14, 2018 8:46 am by goat19642004
» Installing rebuilt 318
Sun Nov 12, 2017 8:21 pm by eva_392
 58 trunk letter measurement
rickster
PostSubject: 58 trunk letter measurement   Mon Feb 06, 2012 10:45 pm
Need another measurement please, since were just about the only people on earth that own the type of cars i have no one else to ask where the trunk letters go properly,i havent done any drilling yet,but what im doing is making a 57 trunk a 58,i cut the front strip of the hood off a horribly rusty 57 plymouth to act as a template,im assuming the letters on the trunk lid of a 58 is the same spacing on the hood of a 57? i found the exact center,marked it,i found that the first pin on the letter h is in the same spot as the first pin on the letter p, so i know how to make the words level across,what i need to know is how far straigth down from the letter p to the bottom of trunk lid is it,i think this should work perfectly if the spacing is the same,or does anybody know a better way,i figured alot of people in this club have done this conversion,or will in the future. thanks for any info i appreciate all the help every one gives so we can all keep are dreams alive. Rick.
PostSubject: Re: 58 trunk letter measurement   Tue Feb 07, 2012 12:22 am
ill take some measurments tomorrow and post them.
cdasho
PostSubject: Re: 58 trunk letter measurement   Tue Feb 07, 2012 2:35 am
Thanks for bringing that up. will have the same problem very soon. Thanks for the measurements in advance..Charlie and jane.
PostSubject: Re: 58 trunk letter measurement   Tue Feb 07, 2012 3:42 pm
I love the way people bend over backwards to help. Sort of brings tears to my eyes. Crying or Very sad
cdasho
PostSubject: Re: 58 trunk letter measurement   Tue Feb 07, 2012 4:02 pm
Bobby if you bent over backwards Im sure you will be crying !!!
PostSubject: Re: 58 trunk letter measurement   Tue Feb 07, 2012 7:34 pm
Okay here we go 10 inches even from side for the p center of the square hole 5 and 9/16 from bottom the in between letters are hard to measure I need a better tape measre since theres a very definfed curve to the decklid, but I can tell you the last letter h is 10 1/2 from side so the holes arent perfectly symetrical from factory ill get a better tape measure to do the in between letters as I dont think those take the same measurment either in between the p and the h hope this helps. Smile
rickster
PostSubject: Re: 58 trunk letter measurement   Tue Feb 07, 2012 10:44 pm
thank you very mutch i can use that,didnt know they were off a little,i think i got what i need but ill wait for your other measurements too, that 5 and 9/16 is from center of first pin hole on p straight down to bottom,right? thanks, rick
PostSubject: Re: 58 trunk letter measurement   Tue Feb 07, 2012 11:04 pm
Yes 5 and 9/16 from center of first hole to bottom. keep in mind the holes are square I guess u can measure the size of the square on the letters so you dont go too big. Your welcome -Carlos
PostSubject: Re: 58 trunk letter measurement   Wed Feb 08, 2012 5:25 am
Thanks from me too Carlos! Now I won't need to ask this same question. Smile
If I remember correctly the post are shorter on the hood ones then the trunk?
cdasho
PostSubject: Re: 58 trunk letter measurement   Wed Feb 08, 2012 5:59 am
Thanks for the post...What they are shorter ? I will be putting 57 Hood letters on my trunk...I guess we shall all figure this out together....
PostSubject: Re: 58 trunk letter measurement   Wed Feb 08, 2012 6:09 am
Yes the clips won't go back on but the letters are the same. Single thickness of metal on the hood double on the trunk lid.
PostSubject: Re: 58 trunk letter measurement   Wed Feb 08, 2012 7:19 am
Charlie now that is funny lol!
rickster
PostSubject: Re: 58 trunk letter measurement   Wed Feb 08, 2012 11:25 pm
your right,i didnt think of that either,humm,back to the drawing board.
PostSubject: Re: 58 trunk letter measurement   Thu Feb 09, 2012 8:27 am
Mine are going on is I have to glue them on. But I was thinking of using JB on the end of the post or maybe cutting round holes in the second layer of metal to get the clips on. Where there's a will there's a way. Smile
cdasho
PostSubject: Re: 58 trunk letter measurement   Thu Feb 09, 2012 8:47 am
Your right if there is a will there is a way !!!
PostSubject: Re: 58 trunk letter measurement   Thu Feb 09, 2012 10:52 am
Got that right Crisy I know you can do it. I would bet on it and win. Smile
PostSubject: Re: 58 trunk letter measurement   Sun Feb 12, 2012 7:01 am
Even 5 minute epoxy will hold with a thin layer on the back of the letter and a little dab from behind in the stud hole. Tape it flat for a while to let it set up. If any bleeds out ,have q-tip realy to sop up the excess. Marc.
