Forum
HomeCalendarFAQUsergroupsRegisterLog inGallery
CCC PODCAST!
» carpet under layment
Yesterday at 11:09 pm by 58plym
» Joe C's 58 Plymouth "Christine" build continued here!!!!!
Yesterday at 11:06 pm by 58plym
» Good Kid & Mom, Bad Dad
Yesterday at 10:59 pm by ChristineIsAwesome
» Sport tone inserts repops! Fill out form to get the ball rolling.
Yesterday at 10:26 pm by JAG
» Red 1958 four door HT In NJ ebay
Yesterday at 10:21 pm by JAG
» "Z" bar bushings in metal not plastic
Yesterday at 9:52 pm by 58plym
» 350-361-383-400 dual quads with some carbs $370
Yesterday at 9:44 am by EvilPlymouth
» i back lol
Yesterday at 8:57 am by 58plym
» fiberglass chromeing
Yesterday at 5:59 am by paul1957
Top posting users this week
EvilPlymouth
sajase57
Statistics
We have 153 registered users
The newest registered user is adelvern
Our users have posted a total of 9695 messages in 942 subjects
 Headlight switch malfunction
FurryFan
PostSubject: Headlight switch malfunction   Tue Feb 07, 2012 2:31 pm
My 57 Plymouth light switch outer ring (a rheostat?) doesn't seem to work. Perhaps it failed being so old. Anyway, all the instrument lights work on the aux side but not in the int side of the switch. How about if I make up a pigtail for the 3 instrument connections and hook those and the tail light connector all into the tail light terminal on the headlight switch? Of course, I'll incorporate a fuse, say 15 amp, into the new pigtail. Will this work and not overload the other wiring? Thanks for your comments. Furryfan
Assistant Administrator
PostSubject: Re: Headlight switch malfunction   Tue Feb 07, 2012 2:49 pm
Wouldn't it be simpler to find a used switch. Check with John ( big M here). Seems like it would be a lot simpler to just replace and should not be that expensive.
PostSubject: Re: Headlight switch malfunction   Tue Feb 07, 2012 3:06 pm
I agre with Jim, You should be able to get another switch, They still are NOS switches out there also, I bought a NOS for mine quite a few years ago. If I can remember I think I paid about 75 bucks for it. One thing I don't like to mess with anything that might cause an electrical problem and start burning wires, I hate nothing more then a wiring problem especially under the dash. Could loose from a few hours rewiring up to replacing our car. Smile
SIR ROBERT THE WISE 1ST KNIGHT OF THE C.C.C.
PostSubject: Re: Headlight switch malfunction   Tue Feb 07, 2012 3:35 pm
I also would not recommend this repair, it may overload the circuit. A fuse would prevent an overloaded circuit fire, but repairing it correctly is the best method.
FurryFan
PostSubject: Re: Headlight switch malfunction   Tue Feb 07, 2012 4:47 pm
I thought of this and agree, but I'm not sure where to find a NOS switch, and if I use an old one the same problem may reoccur. What I haven't confirmed is if the outer ring, call it a rheostat, fails, would that be the reason that the instrument panel lights won't work? The instrument lamps and wiring are all good as they come on when plugged into the accessory connector on the h.l. switch. Over to you for more comments. Thanks, Furryfan.
PostSubject: Re: Headlight switch malfunction   Tue Feb 07, 2012 7:28 pm
Yes it would be a good chance , That is what dims and brightens your dash lights. I have a NOS switch but I am going to keep it, My Dash lights stay on btoight right now with it turned all the way off . So I am going to keep that for a back up for the future if I need it. I like my dash lights all the way up anyways. Smile
The Christine Car Club  :: Christine Car Club Tech Section :: Electrical, Wiring, & Battery:-
