Sun Jan 14, 2018 8:46 am by goat19642004
» Installing rebuilt 318
Sun Nov 12, 2017 8:21 pm by eva_392
 58 PLYMOUTH trunk letter placement
PostSubject: 58 PLYMOUTH trunk letter placement   Sun Feb 19, 2012 8:23 am
If you are using a 57 trunk deck with 58 letters. I do not have 57 letters so this is for the 58 letter spacing only. The pins on the letters are offset based on the letter so the spacing is different for each letter. From the left side of your trunk deck measure up 5 5/8 inches. The first letter P is 9 7/8" over from the left. Measure about 10 3/8/" over on the right side of the trunk. Measure up 5 5/8". Draw a straight line from left to right on your 5 5/8 measurements. The reason for this is when I measured my trunk deck the center letters were a little more then 5 5/8". This now gives you a straight line for you square holes. From the left to the right your measurements for each letter are
9 7/8" 14 11/16" 19 5/8" 24 5/16" 29 1/8/" 33 7/8" 38 15/16" 43 1/2"
P L Y M O U T H
Your last hole should come very close to that 10 3/8" mark you made measuring from the right.
All measurements are center of hole.
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Sun Feb 19, 2012 11:38 am
Jim I used to run my trunk letters where they would say
P-L-U-M-H-O-T-Y
I can remember my friend Gene Mc Cormick back in 63 had a 63 Max Wedge Light Weight and he took the Y off and it said P-L-U-M-H-O-T and that it was It was the fastest car in town and probly the State of Idaho. Smile
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Mon Feb 20, 2012 6:18 am
P L Y M O U T H
Jim do you mean I can't use this with my 57 hood letters? Sad
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Mon Feb 20, 2012 6:54 am
Doesn't mean you can't use them Chrissy. I am not sure on the size or where on the letters the pin mount is on 57 hood letters. I wrote it that way as I did not want anyone with 57 letters to go drilling holes using my measurements and make a mess of their trunk lid. The measurements would all be the same if the mounting pins were dead center of each letter but on the 58 letters they are not. My measurements were more for someone that is converting a 57 and has the 58 letters . I took all these measurements off my 58 trunk lid.
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Tue Feb 21, 2012 6:54 am
Gotcha. I was thinking of mounting them on a piece of card board tell they look right and using that for a template. Some of what you put down may still be helpful to me. And diffidently helpful to others needing to do this. Smile Thanks
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Tue Feb 21, 2012 12:25 pm
Crisy will get it right If anybodyh can Crisyh Can. Smile
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Tue Feb 21, 2012 6:44 pm
I thought about the cardboard myself Chrissy so I guess greats minds work the same. Hee! Hee!
crazy58fury
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Tue Feb 21, 2012 7:23 pm
THAT is really helpful to me for sure cuase Im ganna convert my 57 deck lid to 58, THanks sooo much for putting that down!
Kiddo if you sold him that piece of crap you atta be frikin ashamed of yourself
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Wed Feb 22, 2012 7:42 am
Yes they do Jim. Rolling Eyes Rolling Eyes Hee! Hee!
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Wed Feb 22, 2012 7:44 am
Tanks Bobby. Laughing
PostSubject: Re: 58 PLYMOUTH trunk letter placement   Sat Apr 28, 2012 5:07 pm
thats funny bob i was just going to say it sure would be funny if one of us spelt plymouth wrong putting the letters in the trunk lid
