 Disk brake conversion.
PostSubject: Disk brake conversion.   Sat Nov 19, 2011 11:06 am
Some of our members have had very good luck with these. Ask a question and I am sure they will advise you.
http://www.aajbrakes.com/rproductinfo.html
PostSubject: Re: Disk brake conversion.   Sat Nov 19, 2011 9:37 pm
Yea Jim these kits are the best and easiest to put on , I bought the basic kit from Roger and he even told me I could buy all of the rest of the parts I needed at my local parts house. He is a real square shooter and a nice guy to talk to. He will bend over backwards to help you. Smile
PostSubject: Re: Disk brake conversion.   Thu Jul 19, 2012 10:31 pm
I know I've commented on aaj somewhere else, but it bears repeating! My experiences are the same as sir robert. I highly recommend this. As you know, in order to be factory correct, a forward look mopar's brakes don't work properly.
PostSubject: Re: Disk brake conversion.   Thu Jul 19, 2012 11:25 pm
looks liek a very professional and clean setup i would go with them Jim
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 4:40 am
Yea Joe they say even a 5 year old can Hee! Hee! do it.
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 6:31 am
Looks like you will have to wait another year Joe!!!
Hee! Hee! Hee! Hee! Hee! Hee!
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 9:26 am
I have been thinking very seriously about putting them on the rear of RedSled. I may wait till the back shoes are done for. I don't wear them out like I did , I mean the rear ones since I have put a line lock on RedSled for the burnouts, I am going to try and just do a small burnout , Just enough to wipe my tires off and see how that works, I can't buy a set of rear tires every year. Cost is to much. Smile
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 9:36 am
I wasn't impressed with the Scarebird kit. If I do another I will use the AAJ kit.
Both hoses listed are way to short to meet with the factory hose bracket, and the large pickup truck calipers hit the upper arm, reducing your turning radius.
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 9:48 am
scratch Well Rick the AAJ works perfect , They are a great kit, only thing Is I have to say or rather I keep it a secret that I have a cheby part on my mopar, the calipers Hee! Hee! But if it will make RedSled stop real quick, i don't mind Smile
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 10:43 am
what now both of you are picking on me, i have disc brakes all around already off of my truck Razz Hee! Hee!
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 10:46 am
Well big deal Bucko,I had mine first and done the work myself lol!
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 7:11 pm
I wish I wad in Idaho bob I would give you a pat on the back lol
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 7:20 pm
Here is my AAJ complete Rear Brake Set Up................The Front's I have ready to install as well however I never took the pic's yet. This is just a great set up.
PostSubject: Re: Disk brake conversion.   Fri Jul 20, 2012 7:32 pm
Joe I talked to Roger and he said beings i would not need an emergency brake he could really give me a great deal on the basic kit for the rear. I think i will probly go that way. Will be a Winter Project. Then I will find out about the front for Eva's 65. If yu are going to have to replace some shoes or drums, it wold be a much better way to do it. Then You wouldn't have to worry about shoes a few years down the line' Smile I know I sure love the fronts on RedSled, one of the best things I had ever done to her. Smile
PostSubject: Re: Disk brake conversion.   Sun Jul 22, 2012 5:42 am
Those rear discs look fantastic.....may have to buy a set for the 59 Belvy!!
set426
PostSubject: Re: Disk brake conversion.   Mon Feb 01, 2016 3:23 pm
Does anybody know which calipers and rotors this kit uses? The scare bird is an ok t-bird of I recall and they are not easy to come by and requires 15 inch wheels
