Sun Jan 14, 2018 8:46 am by goat19642004
» Installing rebuilt 318
Sun Nov 12, 2017 8:21 pm by eva_392
 RMS Titanic Control Room Panel
Go to page : 1, 2, 3  Next
PostSubject: RMS Titanic Control Room Panel   Thu Apr 12, 2012 8:52 pm
My son and I have developed quite a fascination since we started our Titanic model. We've recorded and watched every documentary on natgeo and he and I have decided to take our interest to the next level.....
He said "Hey Dad, wouldn't it be cool to have our own "Titanic Room?" I thought about it for awhile and woke up the other morning and drew this while having my morning coffee...
[You must be registered and logged in to see this image.]
We've decided to redecorate our Dining Room into a Study and we'll be building what you see onto the main wall. I've begun buying bits and peices and perfecting my brass and copper polishing skills.... Here are a few pictures of what we've gathered so far...
It won't be 100% historically accurate but will get the point across! The idea is to replicate the Titanic's Water tight door indicator panel with working lights, two side "sconces" with antique gauges and elements of the Marconi wireless room. Everything will "function" at 110V. Lastly we'll be restoring a desk my father had in the basement as long as I can remember and that will be it. I'll be using antique edison style bulbs here and there and paneling the wall with tongue and groove pine painted white. Smile
PostSubject: Re: RMS Titanic Control Room Panel   Thu Apr 12, 2012 9:39 pm
That will be cool Wayne, Yo9u guys are having fun. That is what that matters Smile
PostSubject: Re: RMS Titanic Control Room Panel   Fri Apr 13, 2012 6:00 pm
Why don't you just put the bridge in there too? steering wheel, telegraph engine controls
crazy58fury
PostSubject: Re: RMS Titanic Control Room Panel   Fri Apr 13, 2012 8:50 pm
Awsome!! that will look like it was just off titanic! Awsome job wayne!
Kiddo if you sold him that piece of crap you atta be frikin ashamed of yourself
PostSubject: Re: RMS Titanic Control Room Panel   Fri Apr 13, 2012 11:57 pm
I may add an Engine Room Telegraph one day but that's about the extent of it. Smile
PostSubject: Re: RMS Titanic Control Room Panel   Fri Apr 13, 2012 11:58 pm
Thanks Ty glad you approve! Cool
PostSubject: Re: RMS Titanic Control Room Panel   Sat Apr 14, 2012 6:55 am
Now that's just teriffic! Way to be creative!
PostSubject: Re: RMS Titanic Control Room Panel   Sat Apr 14, 2012 11:08 pm
As we await the arrival of some of the key peices and elements we've decided to restore the morse code key and adjoining parts.
There is so much personality to this piece! After taking several photographs we completely dissasembled it. When we did it revealed the beautiful original stain of the wood of the panel beneath in two places. I was so struck by it that we decided to not strip it down completely. Using 800 grit I carefully removed a thin layer of laquer until the stain appeared as clean and uniform as possible. I've applied the first coat of new laquer over the original stain and it looks phenominal! Can't wait to see it with 3 coats and a good sanding with 1500 grit paper!!!!
While it dries and in between coats we are carefully polishing the brass components. Using 2 buffers the key is to first wash the piece with warm soapy water, dry it thoroughly, then use a clean microfibre cloth and some brasso to remove the top layer of tarnish. THEN on one buffer use a black polishing compound and on the other white polishing compound. The results are breath taking!
PostSubject: Re: RMS Titanic Control Room Panel   Sun Apr 15, 2012 12:06 am
Man that looks great Wayne, IWe are watching A titanic Movie right now named (Anight to Remember ) 1958 Movie. Smile
crazy58fury
PostSubject: Re: RMS Titanic Control Room Panel   Sun Apr 15, 2012 8:37 am
Just beautiful... Cant wait to see it done! Its ganna look amazing
ty
PostSubject: Re: RMS Titanic Control Room Panel   Sat Apr 21, 2012 10:01 pm
The wooden panel is finally done! Had an issue with the Laquer turning white in one coat due to moisture in the air so I stripped that layer and added three more!
The "see saw" lever of the morse code key is not brass. It is supposed to be polished steel. Sadly, surface rust did a fair amount of damage. After repeated sanding and buffing a faint etching or staining from the rust proved impossible to remove..SOOOooo I had it glass beaded and took a chance having it chromed. Can't wait to see the contrast with the polished brass!
PostSubject: Re: RMS Titanic Control Room Panel   Sat Apr 21, 2012 11:50 pm
You know Wayne I think it would be neat to learn how to use a telegraph key. Smile
PostSubject: Re: RMS Titanic Control Room Panel   Sun Apr 22, 2012 12:02 pm
Looking real good.
PostSubject: Re: RMS Titanic Control Room Panel   Mon Apr 30, 2012 7:40 am
Can't wait to see the finessed project. The wood panel looks great and saving the original stain was a good idea. Smile
PostSubject: Re: RMS Titanic Control Room Panel   Mon Apr 30, 2012 9:26 am
Wayne, they were an old Hotel in Caldwell , they had made a really neat resterant out of several years ago , it has been tore down now caught on fire, probly for Insurance, Bujt the whle interior of it was of old ships that had sink, They had so many parts and Items from them, Steering wheels lots of brass thngs you name it. It gave yu a funny feeling just being in there. I know by that how a person could get hooked on Ships that had sink. Smile
PostSubject: Re: RMS Titanic Control Room Panel   Mon Apr 30, 2012 12:40 pm
this is very neat stuff was just wondering what doors in your house these levers will acctuate and if they are actually water tight lol!
[You must be registered and logged in to see this image.] [You must be registered and logged in to see this image.]
PostSubject: Re: RMS Titanic Control Room Panel   Mon Apr 30, 2012 9:19 pm
It sure would be Bob! Hey ya never know right? Wink
Thanks Christine! I'll be finishing up the telegraph key once it warms up here and making a few changes to the "Layout" so Ryan has something special one day! Wink
Sounds cool Bobby. It can be quite alluring. I've fallen hard for the Turn of the century industrial age stuff. It is a tremendously rewarding experience bringing back these "Brass Beauties". Wait till I finish the Large Door Switch! That'll blow your socks off!
Jag wrote:
this is very neat stuff was just wondering what doors in your house these levers will acctuate and if they are actually water tight.
HA! Let me know what you think of my panel when it's done Joe! Smile
PostSubject: Re: RMS Titanic Control Room Panel   Thu Aug 02, 2012 6:34 pm
Oh man thats gonna be fantastic.............its gonna be awsome.
PostSubject: Re: RMS Titanic Control Room Panel   Mon Nov 26, 2012 11:51 pm
Well, the "mad" collecting of tidbits is steadily picking up speed. Here's the newest additions to the projects parts supply! I paid WAY TO MUCH for the brass gauge. Sure looks period correct! Laughing
1 Vintage Brass Pneumatic Vacuum Money Tube - Lamson
1 American Quack Medical Electrical Device in Wood Case
1 Antique Vintage 4 D D HOME MEDICAL APPARATUS electroshock...
1 Vtg A.E. DEAN London BRASS GALVANOMETER Amp gauge MILLI-A...
1 Vintage Brass Boat Light...
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 12:20 am
very cool wayne, this will be one heck of a room when it is finished Very Happy
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 6:25 am
You are putting together some great pieces Wayne. Should look pretty authentic when you are done.
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 7:06 am
[You must be registered and logged in to see this link.]Wayne each piece you add is more fascinating then the one before. Collecting all the things needed for a project is half the fun for me. Glad your taking time to enjoy yourself. Smile
JessicaS
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 9:31 am
WOW! Talk about awesome! Keep the progress pics coming. I can't wait to see how everything comes together. Ryan is one lucky kid!
1955 Desoto Fireflite Coronado
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 10:39 am
Wayne you are making great progress, I bet Ryan's friends are very envious of him, havind a collection like that.Smile
cdasho
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 12:50 pm
that is gonna look way cool. I have been a Titanic buff since I was a kid and I never thought to do anything like that. Im sure it will turn out AWESOME !!!! Keep the pics and updates coming ....
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 1:04 pm
Looks great Wayne, thats a great project and will be something to be proud of as well as provide great memories with you sons.
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 1:49 pm
Those are some excellent pieces, Wayne, and in good condition as well.
Where do you seem to have the best luck finding them, E-bay, or other?
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 8:27 pm
To answer John's question I had the idea to do the "Control Panel" and then the perfectionist in me made me decide to build an exact replica! Now we're in trouble! Ebay and craigslist are the best places. What I had the idea to do was collect certain period items for their parts. Take the medical apparatus for example. All I wanted were the brass peices so there is a method to my madness. I thought I would be the first to do this and found out a gentleman by the name of Ted Sinclair has already done so in the UK! He trolled ebay for 4 years and built everything. His reproduction is breathtaking and it will be hard to beat but ya'll know me! LOL This guy is a 71 year old retired lori driver? Maybe Lee can tell us what a Lori is? LOL
Check it out! [You must be registered and logged in to see this link.]
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 10:04 pm
Thanks brother Joe! Glad you like!
Well, you saw my 4 door Jim! You can expect nothing less when it comes to my efforts and work ethic!
Me too Chrissy. I feel wonderfull and spending more time with the kids is wonderfull!
Thanks Jess! Should have the final pictures of Ryan's completed room in the next week for you too! Smile
They are but I answer all their questions and try and make them feel apart of it by making suggestions and such. Smile
Will do Charlie! Smile
You said it Carlos! Smile
Martin is a HUGE titanic fan and has offered us something very special for our room. He has offered to give us a very large scale model of the ship for just the cost of shipping! Thank-you so much Martin! Smile
PostSubject: Re: RMS Titanic Control Room Panel   Tue Nov 27, 2012 10:14 pm
Wow what an effort......In England they say Lorri which means trucks......The guy is a truck driver.
good luck with it Wayne!!
Page 1 of 3Go to page : 1, 2, 3  Next
The Christine Car Club :: Non Automotive Off Topic Section :: General Discussion/World News & Off Topic Section-
