» Fresh Air Intake?
Yesterday at 2:20 pm by Red Devil
Yesterday at 1:42 pm by JAG
Mon Nov 12, 2018 10:20 pm by ghostsoldier
» 1966 Ford Mustang
Mon Nov 12, 2018 12:54 am by JAG
» RMS Titanic Control Room Panel
Sat Nov 10, 2018 1:43 pm by Bloodhound1958
» Donald M. Morgan/Dean Cundey
Thu Nov 01, 2018 3:22 am by Christinefan824
» Bettie wants to wish all of you and your Babies, a Happy Halloween!
Wed Oct 31, 2018 9:17 pm by Christopher L. Faddis Usn
 installing quarter glass vertical seal
1fine58
PostSubject: installing quarter glass vertical seal   Wed Apr 25, 2012 11:43 am
Do i need to remove the interior to install this seal that runs vertical and seals the quarter glass to the front door glass? I see there is a screw on the bottom of the quarter glass, im assuming i have to remove the door panel and get to the screw from the under side inside the quarter. Thanks Tim.
PostSubject: Re: installing quarter glass vertical seal   Wed Apr 25, 2012 1:37 pm
I just oredered a pair of those off ebay they look nice,Id try androll window down and remove door panel as well as acces panel with a stubby screwdriver you may be able to unscrew it from the inside? Im speculatiing as Ive never tried it but if you cant do it that way you may have to at least partially dissasemble the glass. Smile
PostSubject: Re: installing quarter glass vertical seal   Fri Apr 27, 2012 11:11 am
very interesting let us know what had to be done this can be beneficial to members in the future
1fine58
PostSubject: Re: installing quarter glass vertical seal   Fri Apr 27, 2012 11:29 am
I took the rear seat out and the door panels off and used a screw driver. it comes right out you dont have to take the glass out or anything.
PostSubject: Re: installing quarter glass vertical seal   Fri Apr 27, 2012 1:56 pm
that is awesome to know, would really suck if you had to remove the glass to install
