Sun Jan 14, 2018 8:46 am by goat19642004
» Installing rebuilt 318
Sun Nov 12, 2017 8:21 pm by eva_392
 Running dual exhausts without a crossover.
FurryFan
PostSubject: Running dual exhausts without a crossover.    Wed May 23, 2012 8:21 pm
Hi guys,
I'm running dual exhausts on my '57 Savoy with a 318 Poly. However, I don't have the crossover pipe, and someone recently mentioned that with it the motor should run more smoothly and more efficiently.
The motor now sounds like it has a high lift cam and that is kind of neat. With a crossover pipe in the exhaust system, that might disappear.
What are your thoughts about running dual exhausts without a crossover pipe? Thanks for your input and/or suggestions. And might not using a crossover have an effect on the gas mileage? Furryfan.
PostSubject: Re: Running dual exhausts without a crossover.    Wed May 23, 2012 8:27 pm
Not a heck of a lot of people use a cross over pipe unless you want to get the maximum performance out of them.
If you are running a 318 I wouldn't even worry about it. My own opinion it would ot help enough to put one on.
But I am one guy and that is my opinion.
PostSubject: Re: Running dual exhausts without a crossover.    Thu May 24, 2012 12:31 am
hmmm i would have to agree with Bob with a high HP motor the cross over pipe would probably be more effective
PostSubject: Re: Running dual exhausts without a crossover.    Thu May 24, 2012 6:25 am
Crossover pipes help balance to exhaust pressure from side to side and scavange the exhaust. X is better then H and they help with low end torque. At high RPMS they do not have much effect.
FurryFan
PostSubject: Re: Running dual exhausts without a crossover.    Thu May 24, 2012 1:55 pm
Thanks for your comments, guys. I think I'll just keep the straight-through exhaust system without the cross-over pipe for the time being. That is, unless it becomes some sort of a problem to warrant installing it. I don't think that my gas mileage will be effected, although I have pause when I see the gauge move as I'm looking at it. Just kidding.
Best wishes, Furryfan.
PostSubject: Re: Running dual exhausts without a crossover.    Thu May 24, 2012 3:25 pm
IF YOU WANT TO REALLY SE THE gAS nEEDLE MOVE WHY DON'T YOU PUT A 500 PLUS HP
440 IN IT WITH A BIG OLD CAM AND A 850 HOLLY PLUS LOTS OF OTHER GAS EATING THINGS Hee! Hee! Your 318 shouldn't be that bad on gas. Smile
PostSubject: Re: Running dual exhausts without a crossover.    Fri May 25, 2012 9:23 am
WHAT are you trying to say Bob? scratch you dont get good gas mileage?? scratch
PostSubject: Re: Running dual exhausts without a crossover.    Fri May 25, 2012 10:25 am
Hee! Hee! Most peole say they get miles per gallon, I get gallon's to the Mile Hee! Hee!
PostSubject: Re: Running dual exhausts without a crossover.    Fri May 25, 2012 11:14 am
hahah i hear you Bob i will be sad once my christine is done lol!
PostSubject: Re: Running dual exhausts without a crossover.    Fri May 25, 2012 12:03 pm
Well at least you won't be driving a UGO Hee! Hee!
PostSubject: Re: Running dual exhausts without a crossover.    Tue Jul 25, 2017 3:50 pm
I can only imagine what my mileage will be when I get TootsC ('57 Belvedere 2dr ht) on the road. She will have a 440 @ .030 over, Mopar purple shaft (292 duration and .509 lift) and dual quads. On the other hand, since it not going to be a daily driver, who cares? At my age it's about time I did my last and most powerful Plymouth. Some of you have seen pictures of my last one, Eva 392.
