| Author | Message |
Arnie1964 Assistant Administrator
Posts: 721 Join date: 2011-11-08 Age: 65 Location: NC
 | Subject: Torqueflite rebuild kits Mon Nov 21, 2011 2:11 pm | |
| http://www.autotran.us/tfkits1.html |
58plym Assistant Administrator
Big Block 440 Posts: 2378 Join date: 2011-11-06 Age: 70 Location: Nampa ID USA
Big M CCC Member
Big Block 361 Posts: 572 Join date: 2011-11-10
 | Subject: Re: Torqueflite rebuild kits Mon Nov 21, 2011 2:32 pm | |
| Another good source is Fatsco. They have full and partial kits available.
Gary Nelson [the parts doc] is another supplier for the kits, but he is retiring from parts sales. He is a supplier to the 300 club members.
---John |
RacerRick CCC Member
Posts: 144 Join date: 2011-11-14
 | Subject: Re: Torqueflite rebuild kits Thu Dec 15, 2011 2:26 pm | |
| One thing to remember when you get a blown up trans rebuilt - replace the converter and flush the cooler and lines! Unless you get the coverter cut open and professionally cleaned out, you are just putting a bunch of trash right back into your fresh new trans. For a stock converter, its usually the same price for a rebuilt one as it is to get yours cut open and cleaned out. Might as well go for a little more stall also Same for the cooler lines and cooler. Plus you get to check to see if the cooler is plugged! |
 | Subject: Re: Torqueflite rebuild kits Thu Dec 15, 2011 2:51 pm | |
| Rick That is some of the best advice you can give anybody, Lots of people takes great care of their engine and never even thinks about the tranny. Yea need to flush the lines out and as you say the convertror will still have the crud in it and jusat as soon as it starts up it is right back in your tranny. In my 58 I change tranny fluid very often and make sure you change your filter every time you do the fluid. I can remember back in the olden days  a person would only change their oil filter every other time. _________________ SIR ROBERT THE WISE 1ST KNIGHT OF THE C.C.C.   |
Bluebird57 CCC Member
Posts: 12 Join date: 2012-02-22
 | Subject: Re: Torqueflite rebuild kits Fri Apr 13, 2012 3:16 am | |
| I've been getting a load of TF parts from pat blais on Ebay. I recommend him insofar! |
EvilPlymouth Administrator/Event Manager/Pr.Rep
"Show Me Scene" 350GC BB Posts: 511 Join date: 2011-11-06 Age: 41 Location: New York Baby!
 | Subject: Re: Torqueflite rebuild kits Fri Apr 13, 2012 10:06 am | |
| Fatsco in NJ is the best source for these part's IMO. I used them twice with no disappointment's. _________________ GO AHEAD, MAKE MY DAY!!!!!!!!!!
I'd Rather Be Hated For The Person I Am, Than Loved For The Person I Am Not!
 | Subject: Re: Torqueflite rebuild kits Fri Apr 13, 2012 11:18 am | |
| Good Info Joe Thanks, Im sure this will help some of our members _________________ SIR ROBERT THE WISE 1ST KNIGHT OF THE C.C.C.   |
318Fins CCC Moderator
Posts: 420 Join date: 2011-11-14 Age: 36
 | Subject: Re: Torqueflite rebuild kits Fri Apr 13, 2012 12:25 pm | |
| I used a Fatsco kit Joe recommended a while back, I just hope my Trans guy did a good job on it, the cool part about Fatsco is they use all fresh parts, Unlike Kanter whom sells decades old kits.I used Kanter the last Tf i had done and it did work however they sent me the wrong kit,A Powerflite kit for a Torqueflite, they took so long to adress the problem I just went to my local trans store and bought the extra clutches that were missing. I heard the Tourqueflite uses a special tool to get the sprag in my trans guy says he was able to install without making a tool im scared....Hope it works. Your right Rick cutting open the converter the only way, I had my done for $150 locally and the guy told me that while the converter wasnt damaged it did have 2-4 lbs of rust sludge! no way no how would it have worked without cleaning it out. |
 | Subject: Re: Torqueflite rebuild kits Fri Apr 13, 2012 2:19 pm | |
| I have a friend that has done trannys for about 50 years he is retired now and has a full tranny shop in his back yard. He does all my trannys for 350.00 That is torqueflight Ford or cheby, yea I had a cheby done here about three or four years ago in my old motorhome it has a 400 in it. 350.00 parts and labor, now in my 58 It has a reverse valve body bolt in sprags ect , cost me for the extra parts  Can't afford to build one yourself for that price. Only problenm I ever had with his trannys was not his fault, Broke a case in my 63 once and he put everything in a new case and cleaned it up. wasn't going to charge me but I gave him 100.00. I thought it was well worth that.  Nice to have a friend that is a tranny expert. _________________ SIR ROBERT THE WISE 1ST KNIGHT OF THE C.C.C.   |
